  • Darpan 4 posts 20 karma points
    Jul 18, 2009 @ 12:39
    Darpan
    I am facing problem of � character in Rich text editor
    Hi All,
    I am new in umbraco. I am using Rich Text Editor as a property. When I press "Enter" key I am getting '�' character on screen.
    can anybody help me?
    Thanks in advance
    Darpan
  • Peter Dijksterhuis 1442 posts 1722 karma points
    Jul 18, 2009 @ 13:05
    Peter Dijksterhuis
    check your umbracoSettings.config file (in config folder). Look for the line:
    <TidyCharEncoding>UTF8</TidyCharEncoding>
    It should be UTF8 there, if not, make the change, save the file. Just to make sure, open the web.config, add a space somewhere and save it. (to force an application restart)
    Now, if you edit a page, the weird characters should not come back.
    HTH,
    Peter
  • SaphuA 124 posts 87 karma points
    Jul 18, 2009 @ 14:21
    SaphuA
    Wasn't this solved in 4.0.2.1?
    Jul 18, 2009 @ 14:26
    Peter Dijksterhuis
    Yes
    Jul 29, 2009 @ 13:01
    Darpan
    Thanks Peter. It Works
  • jigar 170 posts 233 karma points
    Jul 29, 2009 @ 17:50
    jigar
    Hi peter please mention that the solution is courtesy by jack (Jigar).. Just kidding mate...
