  • kerstin 11 posts 30 karma points
    Mar 27, 2012 @ 09:41
    kerstin
    contour form package not working
    hello,
    I hope someone can help me.
    I already installed the form package contour, which worked fine. I also made all the adjustments.
    the problem is I cannot get it into the webpage, I get this error:
    That is the HTML code:
    <h1>KONTAKTFORMULAR</h1><p>
    </p><div umb_macroalias="umbracoContour.RenderForm" umb_formguid="7fe59e59-9d5c-4211-844f-e1b6ba028640" ismacro="true" onresizestart="return false;" umbversionid="b83ecca5-b835-4df6-b223-19f7f3371719" umbpageid="1225" title="This is rendered content from macro" class="umbMacroHolder"><!-- startUmbMacro -->
    <div id="contour"class="kontaktformular contact"><h4 class="contourPageName">Contact</h4>Kontaktformular<div class="contourField text name textfield mandatory"><!-- Our label -->Name<div></div><!-- Our Tooltip --> <!-- Validation --> </div>
    <div class="contourFieldtext email textfield mandatory alternating">
    <!-- Our label-->Email<div></div><!-- Our Tooltip -->
    <div class="contourFieldtext nachricht textarea mandatory">
    <!-- Our label -->Nachricht<div></div>
    <div class="contourNavigation"></div></div><!-- endUmbMacro --></div>
    where exactly do I put this runat=server?
    thank you very much in advanced :-)
  • Comment author was deleted
    Mar 27, 2012 @ 10:13
    Hey,
    You'll need to place that on your template, how are you placing the form, also in your template or in the rte?
    Mar 27, 2012 @ 10:23
    Mar 27, 2012 @ 15:12
    kerstin
    I really don't get it, how do I add this form to a page?
    where do I put this runat=server tag? ;-(
    Mar 27, 2012 @ 15:15
    Well you'll need to add this to your template, you could add this to your master template just after the body tags ... or surrounding the umbraco item tag that outputs the RTE property
    Mar 27, 2012 @ 15:39
    kerstin
    thanks again tim, but if I add it into the master.template, then it will be shown on every page!!
    I just want that contactform to be shown under contact.
    Mar 27, 2012 @ 15:40
    kerstin
    and by the way, what is RTE? :-)
    Mar 27, 2012 @ 15:47
    RTE is richt text editor ;)
    Do you have a template for your contact page, how does that look?
