I see that it is possible to change a member's username in the back-end.
My client wants to use email addresses as usernames, therefore if a member changes their email address on the website I need to run a bit of code to change their username too.
Does anyone know how I can hook into the provider code that's used in the back-end to do this? I'm imagining that would be the simplest thing to do?
Changing a member's username
Regards,
Matt
Where do you want to change it, from code or from backend?
Hi Scott,
Sorry for the delay in getting back to you. I was at CG12 and wanted to check my solution back in the office before replying.
I found it was quite easy to change the username using the 'original' Membership API.
umbraco.cms.businesslogic.member.Member uMember = umbraco.cms.businesslogic.member.Member.GetMemberFromLoginName(currentUsername);
uMember.LoginName = newUsername;
uMember.Save();
Regards,
Matt
