  • Ron Brouwer 273 posts 768 karma points
    Jul 20, 2009 @ 15:06
    Ron Brouwer
    Attaching OnChange or AutoPostBack to a Contentpicker
    I'm creating a datatype that uses a contentpicker.
    <%@ Register TagPrefix="umb" Namespace="umbraco.controls" Assembly="umbraco" %>
    <umb:ContentPicker ID="cpMyContent"  runat="server"></umb:ContentPicker>
    What I need is to add an OnChange event or at least an AutoPostBack to change the contents of some related fields.
    Any help is much appreciated.
    Ron
    Jul 20, 2009 @ 18:34
    Ron Brouwer
    Anyone?
  • Simon Justesen 436 posts 203 karma points
    Jul 20, 2009 @ 21:26
    Simon Justesen
    I'm listening :) I've done something similar in the past with the Mediapicker. I had to implement it into a datagrid and adjusted the mediapicker source accordingly. But it was quite an ugly hack, so it's not recommendable. I hope there are better ways of integrating existing controls into new ones like you're trying to archive.
    Jul 21, 2009 @ 08:40
    Ron Brouwer
    Any help woul be much appriciated, so if you could point me into the right direction.
    Doe anybody know who created the contentpicker?
    Ron
    Jul 21, 2009 @ 11:00
    Ron Brouwer
    There must be someone..
  • Martijn Beumers 13 posts 172 karma points
    Jul 21, 2009 @ 11:36
    Martijn Beumers
    Nope, this problem is too complex. So it seems :)
  • Jeroen Breuer 4909 posts 12266 karma points MVP 6x admin c-trib
    Jul 21, 2009 @ 11:56
    Jeroen Breuer
    There is a simple workaround. It's not really nice, but you can add an extra button to the datatype and when a new value has been selected in the contentpicker the button can be pressed to update the contents of some related fields. It's not nice but it works.
    Jul 21, 2009 @ 12:10
    Jeroen Breuer
    Wait I have a better idea. You can copy the contentpicker from the source code and edit it so it can do a postback if you want to. In the source code the file is located at: umbraco/presentation/umbraco/controls/ContenPicker.cs. You should not edit it in the sourcecode but copy it to your own project and edit it there.
    Jul 21, 2009 @ 15:15
    Ron Brouwer
    Thanks for your input Jeroen,
    I choose a different solution:
    <script type="text/javascript" language="javascript">
                    <%=cpMyContent.ClientID%>_updateContentTitle = function() {__doPostBack("", "")};
                    <%=cpMyContent.ClientID%>_clear = function() {
                            document.getElementById("<%=cpMyContent.ClientID%>").value = "";
                            __doPostBack("", "");
    </script>
    I know its a bit dirty but it does the trick.
    Ron
