4.1.0 beta: All trees empty suddenly - production site :-(
I know this is an old one - but never touch a running system, you know.
I have an Umbraco 4.1.0 beta installation running a customer website since this beta was published. Worked fine, worked stable - there never was a real reason to upgrade or mirgrate.
But now - from one day to the other - all trees are empty. Context-Menus are not showing up either. After logging in it loads the visual frame and so on, but alle trees are empty.
The website wasn't touched for month. Could some cache-files run full? A database table run "full"?
I looked in the forum, there are several similar problems but no solution I found helped. A few weeks ago it worked perfectly, now its dead?
Looking forward for some help or a clue, where to check.
Don't ask me. After trying an update to version 4.5 which didn't work out the way I wished and an restore of the previosly saved folder all trees are back.
I have totally NO clue what I did - but it worked?
Thanx, Arnim.
Greets, Arnim.
I had this issue and after restarting the webserver everything was back to normal, thsi is the trouble with running the beta software.
