  • Collin 42 posts 62 karma points
    Apr 24, 2012 @ 11:09
    Collin
    Manage hostnames and currently set domains
    I'm working on translating a site to multiple languages, and each language will be its own site and have its own domain.
    I know how I need to configure this in Umbraco via "manage hostnames". However I don't have an idea of how I can see the currently configured hostnames/domains for this Umbraco install (4.5.2).
    Where can I see this in the UI? Or is there a configuration file where this is stored? (I'm not talking about configuring domains in IIS, I want to figure out where Umbraco stores this)
  • Mike Chambers 636 posts 1253 karma points c-trib
    Apr 24, 2012 @ 11:35
    Mike Chambers
    It's in the umbracoDomains table in the database....
    SELECT  [id] ,[domainDefaultLanguage],[domainRootStructureID],[domainName] FROM [DATABASE].[dbo].[umbracoDomains]
    Or you can create a usercontrol to iterate through them if you aren't able to access the database.
    There are some methods in this namespace that may help...
    umbraco.cms.businesslogic.web.Domain
    Apr 24, 2012 @ 11:39
    Collin
    I was hoping that I wouldn't need to go to the database or write a usercontrol (I don't have database access so I need to write a usercontrol).
    Why isn't there support for this in the Umbraco UI?
  • Stefan Kip 1614 posts 4131 karma points c-trib
    Apr 24, 2012 @ 11:44
    Stefan Kip
    The currently configured hostnames for a node are in the same 'Manage hostnames' window: http://webmove.be/media/9276/manage-hostnames-2_500x423.jpg
    If you'd like to see all configured hostnames, it will be a DB/usercontrol action, like Mike suggested
    Apr 24, 2012 @ 11:46
    Collin
    Ah thanks. For some reason another site never showed that information (while I knew there was a domain configured), hence I was asking about the UI support.
    With this I should be able to find out how everything is configured and change the setting where needed.
    Apr 24, 2012 @ 11:54
    Mike Chambers
    I wasn't sure if you were coming to a site completely unawares of it's structure... having to "right click">"manage hostnames" for every node to discover if it had a hostname etc... could become very tedious very quickly..... :-)
    Apr 24, 2012 @ 13:11
    Collin
    Well there are currently just 3 site nodes, so that's not really tedious. However, creating all the pages that I need for static text testing and macro testing is quite tedious. ;)
