Hi all, I am new to Umbraco but not XSLT. I was reading in the wiki about "How Umbraco uses XSLT"
1. Go to the developers section in the administration area. 2. Right click on the XSLT folder, and select create. 3. You will receive a dialog where you can specify the name, select an XSLT template, and specify if you want to automatically create the Macro for this template.
With regard to the first 1. bullet item.
Go to the developers section in the administration area... Where is this? I am looking at Web Matrix and do not see that anywhere.
Newbie question about Xslt Macros
You must log to backend - run your site and then add umbraco to end like www.example.com/umbraco/ login and you see sections...
BTW Xslt is used only with umbraco 4. In umbraco 5 it is replaced by razor macros...
So what do I use for a login? I do not remember ever creating a username pwd.
