Hi All,
I am creating a multilingal site (15 languages) and so far so good with the dictionary items.
The only problem I get is the text for the submit buttons I cant seem to get the dictionary items to pull through.
This is my code
[code]
<input type="submit" id="submit" name="submit" value="<umbraco:Item field="#Send" runat="server"></umbraco:Item>">
[/code]
Tom
Replace the single quotes in value="<umb...." with single quotes:
<input type="submit" id="submit" name="submit" value='<umbraco:Item field="#Send" runat="server"></umbraco:Item>'>
Wow that was quick!!!!
Cheers Sebastiaan that worked a treat
Great! :)
You can mark my answer as the solution so that others know that they don't have to answer it and can find a good solution. Use the green checkmark to do that.
I thought I did that on your inital response..... hmmm thats weird.
Well done it again anyway. :)
Dictionary Item into submit text
Hi All,
This is my code
[code]
[/code]
Tom
Great! :)
