I have deployed my site to a shared host. On local pc everything works A Okay, but on the host I cannot access any base url. It gives me the following error:
Unable to load one or more of the types in assembly 'AjaxControlToolkit, Version=4.1.51116.0, Culture=neutral, PublicKeyToken=28f01b0e84b6d53e'. Exceptions were thrown: System.Security.SecurityException: Request failed. System.Security.SecurityException: Request failed. System.Security.SecurityException: Request failed.
Actually, now I'm getting the following error when trying to load a base path such as "/Base/Autocomplete/GetKeywords/word":
Source Error:
Stack Trace:
umbraco.presentation.umbracobase.restExtension..ctor(String extensionAlias, String methodName) +544
umbraco.presentation.umbracobase.requestModule.httpApp_PostAcquireRequestState(Object sender, EventArgs e) +712
System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +148
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +75
I got the same error while trying to pull some JSON/SML out of umbracro via /Base class. Got exactly the same error,and the error was because my custom class.cs file was set as "Content" rather then "Compile" in the property pane.
After set it as compile all worked fine. Even if this wasn't your problem, at least it's very likely that someone land in this post as I did due to the same error message, so, if it doen't help you , it will certainly help out someone else.
Base paths giving weird error
What's the cause of this ?
Come'on umbracians! How can it be that no-one has seen this error before ?
Does Base use the AjaxControlToolkit ? Some help needed here !!!
Source Error:
Hello!
Cheers!
