  • Floffy 26 posts 33 karma points
    Apr 29, 2012 @ 22:18
    Floffy
    Migrating pages (as a package) fails (Object reference not set to an instance of an object.)
    After upgradig a few times (from 3.x to 4.7) I started running in to diffrent problems, so I desided to "Start over".
    Sites running on a MySQL 5.1.51, Windows Server 2003, IIS 6.0, .net 4.0
    Old site is Umbraco 4.7.0, new is 4.7.2
    So I created 3 packages:
    • Dokument types + templates + stylesheets + data types
    • Macros
    • Content
    Changed umbraco.config ForceSafeAliases to false due to use of captital starting letter in properties. (plan to change after install)
    The two first installs but the contents fails, with this:
    Source Error:
    Stack Trace:
       umbraco.cms.businesslogic.Content.CreateContent(ContentType ct) +118
       umbraco.cms.businesslogic.web.Document.MakeNew(String Name, DocumentType dct, User u, Int32 ParentId) +300
       umbraco.cms.businesslogic.web.Document.Import(Int32 ParentId, User Creator, XmlElement Source) +370
       umbraco.cms.businesslogic.packager.Installer.InstallBusinessLogic(Int32 packageId, String tempDir) +3611
       umbraco.presentation.developer.packages.Installer.processInstall(String currentStep) +180
       umbraco.presentation.developer.packages.Installer.Page_Load(Object sender, EventArgs e) +405
       System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14
       System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35
       System.Web.UI.Control.OnLoad(EventArgs e) +91
       umbraco.BasePages.BasePage.OnLoad(EventArgs e) +14
       System.Web.UI.Control.LoadRecursive() +74
       System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2207
    Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.237
    In the log there is one error entry:
    At /umbraco/developer/packages/installer.aspx?installing=businesslogic&dir=c:\webs\talkactive\web431781\prod.bfnsj.dk\App_Data\b57d254d-91a0-4b79-bf0c-e2031715f26a&pId=7 (Referred by: http://prod.bfnsj.dk/umbraco/developer/packages/installer.aspx): System.NullReferenceException: Object reference not set to an instance of an object.
       at umbraco.cms.businesslogic.Content.CreateContent(ContentType ct)
       at umbraco.cms.businesslogic.web.Document.MakeNew(String Name, DocumentType dct, User u, Int32 ParentId)
       at umbraco.cms.businesslogic.web.Document.Import(Int32 ParentId, User Creator, XmlElement Source)
       at umbraco.cms.businesslogic.packager.Installer.InstallBusinessLogic(Int32 packageId, String tempDir)
       at umbraco.presentation.developer.packages.Installer.processInstall(String currentStep)
       at umbraco.presentation.developer.packages.Installer.Page_Load(Object sender, EventArgs e)
       at System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e)
       at System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e)
       at System.Web.UI.Control.OnLoad(EventArgs e)
       at umbraco.BasePages.BasePage.OnLoad(EventArgs e)
       at System.Web.UI.Control.LoadRecursive()
       at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
    Any ideas? Either to fix or work-around?
