Yes, but when I go to StartupDashboardSection, umbraco load two tabs GetAllOpenLots and GetAllClosedLots, I want to do such thing, when I click on tab GetAllOpenLots it is load only this tab, if I want to see last tab I must waiting when previous tabs are loading(for example I will have 10 tabs)
Is there any other solution to load only one tab in umbraco 4.8.1 dashboard. Our site have 5 tabs and loading has become extremely slow. Modify the UI will not work for us since it is a live site. Is there any way to set rules in dashboard .config file.
Thanks for the reply. However it seems that <access> configuration is used to set permissions on sections, tabs and controls to grant or deny certain usertypes access. But my issue is same as that of Anton and it doesnt have nothing to do with setting access permissions . Is there any other option than modifying the UI for this issue as our dashboard is taking a lot of time for loading.
Ah ok, thought you were after options/settings for the Dashboard.config itself.
In what way could the UI be modified to reduce the loading time? The dashboard controls are ASCX user-controls, so the page event lifecycle would execute when it is loaded in.
Did my solution for Anton not work for you? (Keep in mind that I have no idea what you are trying to do with the dashboard controls or how much data you are loading in)
Right now I used Lee's solution. I added a button that when clicked adds the current DateTime to a session and then reloads the page. The usercontrol in the tab will load for 20minutes. But it's still a workaround.
Does anyone know how to do this with Javascript? Is it possible to discern when the tab is clicked on so that the loading can be initiated through AJAX?
Dashboard question
Now I have many tabs in dashboard, how I can load only choosen tab, because now it is loading all tabs and it is very slowly
Hi Anton,
The dashboard controls are managed by a configuration file, this can be edited to display the controls/tabs that you want.
The file can be found at: /config/Dashboard.config
Cheers, Lee.
<section alias="StartupDashboardSection">
<access>
<deny>translator</deny>
</access>
<areas>
<area>content</area>
</areas>
<tab caption="GetAllOpenLots">
<control>/usercontrols/Table/GetAllOpenLots/All.ascx</control>
</tab>
<tab caption="GetAllClosedLots">
<control>/usercontrols/Table/GetAllClosedLots/All.ascx</control>
</tab>
</section>
By default, all controls in the tabs (for the defined area/section), will load automatically - regardless of when you click to view them.
If one of your other tabs takes a long time to load, then that will delay all tabs.
You may want to look at modifying your UI, so that the data is loaded on-demand, e.g. with a button click?
I don't know of another way to delay the loading.
Cheers, Lee.
Thanks, I will modify my UI
Hi Lee,
Regards,
Salam
Hi Salam,
Take a read over the Dashboard.config documentation - you might be able to use the <access> configuration?
http://our.umbraco.org/wiki/reference/files-and-folders/dashboardconfig
Cheers, Lee.
Hi Lee,
Many thanks
Salam
Hi Salam,
Cheers, Lee
I'm having the same problem.
Martin
