  • reza zamiry 1 post 21 karma points
    May 20, 2012 @ 13:57
    reza zamiry
    Farsi and rtl support....
    hi
    i'm new in umbraco...
    does umbraco support farsi(persian) and rtl or not?
    is there any tranlation to Farsi or my self should do it?
    thank's
    May 21, 2012 @ 14:55
    Lee Kelleher
    Hi Reza, welcome to Umbraco.
    I am no expert on translations, but as far as I am aware there isn't an available translation for Farsi.  If you could do a translation that would be excellent!
    To do this, go to the folder: "\umbraco\config\lang\", make a copy of the "en.xml" (English), name it "fa.xml", open in your text-editor and make your translations.
    Once you have the translation file in place, you will be able to select it in the Users section from the available languages drop-down.
    I'm not sure how much demand there is for Farsi, doubt it would be bundled with the Umbraco core distribution, but I'd definitely suggest making it available in the projects section. (Same as the Chinese language is available)
    Cheers, Lee.
  • Babak 1 post 20 karma points
    Sep 06, 2015 @ 22:29
    Babak
    Hi , I'm Persian too, I would love to translate Umbraco which is an awesome CMS and I truly love it.
