  • James Crane 34 posts 80 karma points
    Jul 28, 2009 @ 09:55
    James Crane
    Missing description label in content node
    I have created a document type that features a rich text box. However, when an item is added to the content tree the description label is missing - just the rich textbox is rendered. If I change the control type to normal text, it renders fine.
    Any ideas would be appreciated.
    JC
  • Peter Dijksterhuis 1442 posts 1722 karma points
    Jul 28, 2009 @ 10:01
    Peter Dijksterhuis
    You can enable this in the developer-section. If you go to the developer-section, then go to datatypes and select the richtext.
    There should be a checkbox: Show label. By default, that is not checked. Check the box and save.
    Now if you go to the Content-section and edit a page, the label should show correctly.
    HTH,
    Peter
    Jul 28, 2009 @ 11:49
    James Crane
    Thanks Peter - that fixed it!
