Best to set the language at the rootnode of your site. Right click on the node select Manage Hostnames, the domain name doesn;t have to be a real domain so you can simply say UK and select the Uk Language. That should work
That sounds really helpful. Unfortunately I think me deleting US from the language options has caused a somewhat catastrohic in the content nodes - every one I click (including the manage hostnames box) now comes up with the following error:
Value cannot be null.<br>Parameter name: value body {font-family:"Verdana";font-weight:normal;font-size: .7em;color:black;} p {font-family:"Verdana";font-weight:normal;color:black;margin-top: -5px} b {font-family:"Verdana";font-weight:bold;color:black;margin-top: -5px} H1 { font-family:"Verdana";font-weight:normal;font-size:18pt;color:red } H2 { font-family:"Verdana";font-weight:normal;font-size:14pt;color:maroon } pre {font-family:"Lucida Console";font-size: .9em} .marker {font-weight: bold; color: black;text-decoration: none;} .version {color: gray;} .error {margin-bottom: 10px;} .expandable { text-decoration:underline; font-weight:bold; color:navy; cursor:hand; }
Value cannot be null. Parameter name: value
Exception Details: System.ArgumentNullException: Value cannot be null. Parameter name: value
Source Error:
I went into the table 'umbracolanguage', and added en-US back manually setting the primary key to 1 (which I guessed was the original value) and the site/content tree sprang back into life.
I also implemented Richard's suggestion above and it worked a charm.
I had the same problem, that I got this error, when trying to enter
the Content section. Then I went to the documents as suggested in this
post. I saw, that each document could not enter the masterpages folder.
I added the aspnet user to the security settings. After having done
these settings, there were some errors in my masterpages, solved them
and then I could see my document settings and the Content pages.
Everything works fine.
Hope this will help someone who is facing the same problem.
Changing culture
I am formatting strings as currency and the currency symbol is US$, rather than UKĀ£. I did the following to change the culture:
1. Removed US a language under settings --> Languages
2. Changed web.config to include <globalization requestEncoding="UTF-8" responseEncoding="UTF-8" uiCulture="en" culture="en-GB"/>
However it's still formatting as US($). Looking at the debug screen I can see this is being set: 'default.aspx Culture changed to en-US'.
So, my question is how do I set my culture to be en-GB and what have I missed!
Thanks for any help.
JC
Hope it helps you,
Richard
Thanks Richard,
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.Parameter name: value
Source Error:
I tried to re-add it but I suspect this is a key contraint that's now broken. Possibly looking like a db rollback.
JC
Update!
Thanks Richard.
JC
Hi there,
I had the same problem, that I got this error, when trying to enter the Content section. Then I went to the documents as suggested in this post. I saw, that each document could not enter the masterpages folder. I added the aspnet user to the security settings. After having done these settings, there were some errors in my masterpages, solved them and then I could see my document settings and the Content pages. Everything works fine.
Best, Martin
