  • Smeets Vincent 3 posts 23 karma points
    May 30, 2012 @ 17:58
    Smeets Vincent
    Using a dictionaryItem in a an Umbraco PageField as altText. [4.7.1]
    Hello everyone,
    I would like to use a dictionary item when a specified document field is missing or empty.
    Before using any XSLT, I'll like to know if it's possible to do it in a single umbraco:Item line like this :
    <title>
    <umbraco:Item field="title" textIfEmpty="[#SEO_Title]" runat="server"></umbraco:Item>
    </title>
    doesn't work and inserting <umbraco:Item field="#SEO_Title" runat="server"></umbraco:Item> in the textIfEmpty attribute failed too.
    I almost certain I saw this trick in an umbraco.Tv but i can't find it again.
    Thanks for your advices.
  • JohnC 37 posts 61 karma points
    May 30, 2012 @ 18:02
    JohnC
    have you tried?
    <umbraco:Item field="title" textIfEmpty="#SEO_Title" runat="server"></umbraco:Item>
    I am sure i remember something about the square brackets
    May 31, 2012 @ 09:34
    Smeets Vincent
    Yes and it unfortunately doesn't work :/
