I just got a call from a customer, who has an umbraco 3.0.6-installation. During creation of new pages, she says that umbraco froze up and removed a child folder and child-child documents. Are there any way to revive the pages? I'm a bit hesitant to just republishing the entire page, as it could make reviving even more difficult, or?
Thanks for your reply :) No nothing in the bin (first place I checked ;-)) and nothing in umbraco.config, it seems .. I think I'll ask her webhost if they can do a restore.
Reviving documents
Save the /data/umbraco.config... the old data might still be in there and you can re-import it in the worst case.
I'm guessing there's nothing in the recycle bin, eh?
Any backups that would have had the old content? Again, could be used a source for re-importing the old content.
cheers,
doug.
Hi Doug,
