  • Alvaro 7 posts 27 karma points
    Jun 04, 2012 @ 12:36
    Alvaro
    Rich Text Editor
    Hi!
    I hhave noticed that when writing text in a Rich Text Editor, when the page is rendered, the text is wrapped in <p> tags. however, if you write it in the html pop-up (by clicking in the html button) it doesn't happen.
    Is it possible to avoid this wrapping?
    Thanks.
  • Rik Helsen 670 posts 873 karma points
    Jun 04, 2012 @ 13:11
    Rik Helsen
    it's actually best practice, and allows you to put white spacing between paragraphs.
    You're probably not familiar with the difference between "Enter" and "Shift-Enter" at the end of a sentence? (one goes to new paragraph, the other to a newline in the same paragraph. It's the same in many applications like Word etc)
    There are probably ways to disable it, but personally I wouldn't do it.
  • Fuji Kusaka 2203 posts 4220 karma points
    Jun 04, 2012 @ 14:28
    Fuji Kusaka
    Hi Alvaro,
    If you are inserting an umbraco field in the  template you could remove  the Paragraph by Checking the Remove Paragrah Tags
      <umbraco:Item field="bodyContent" stripParagraph="true" runat="server" />
    //fuji
    Jun 04, 2012 @ 16:35
    Alvaro
