  • Mikael Mørup 297 posts 326 karma points
    Jul 30, 2009 @ 10:38
    Mikael Mørup
    tinyMce template plugin
    I am trying to get the tinyMce template plugin to work, following the instruktions here:
    http://our.umbraco.org/wiki/how-tos/enabling-the-%27template%27-plugin-for-tinymce
    (I know, i know, but my client want it that way :-)  )
    So far i have most of it working, the button shows up in the tinyMce toolbar, the dialog pops up and presents the dropdown with the templates i defined in the config file.
    But whenever i select a template from the drop down i get this message:
    Page not found
    No umbraco document matches the url 'http://localhost/test/twocols.aspx'
    umbraco tried this to match it using this xpath query'/root/node/node [@urlName = "test"]/node [@urlName = "twocols"] | /root/node [@urlName = "twocols"]')
    I defined my template in a file called twocols.aspx and put it in a folder under wwwroot called test. I believe that this is my problem. The aspx file is not created with Umbraco.
    How can i cretae my templates so Umbraco / tinyMce can find them. I have assigned accessrights to the test folder.
  • Richard Soeteman 4054 posts 12927 karma points MVP 3x
    Jul 30, 2009 @ 11:58
    Richard Soeteman
    You need to exlude this file (or the whole test folder) in your web.config so Umbraco doesn't pick this file up. Use the setting umbracoReservedUrls  for a single url. Or umbracoReservedPaths for a complete folder, examples:
    <add key="umbracoReservedUrls" value="/config/splashes/booting.aspx,/install/default.aspx,/config/splashes/noNodes.aspx, /test/twocols.aspx" />
    <add key="umbracoReservedPaths" value="/umbraco,/install/,/test/" />
    Hope this helps you
    Jul 30, 2009 @ 13:44
    Mikael Mørup
    Thanks Richard.
    It did change things, now it's not Umbraco trying to open the page, but insted i just get an ordinary 404 error.
    I tried using the .aspx  .html, and .txt file extensions, but they all result in a 404 error.
    I  wonder what i'm doing wrong here ??
    Jul 30, 2009 @ 13:59
    Richard Soeteman
    It Should work now. Absolutly sure the filename and directory are okay?
    Jul 30, 2009 @ 21:03
    Mikael Mørup
    Yes of course you were right. I had a stupid double fileextension like twocols.txt.aspx.
    Fixed that and now it works perfectly.
    Thanks a LOT.
    Mikael
