  • Rocoeh 65 posts 86 karma points
    Jun 14, 2012 @ 16:36
    Rocoeh
    Media Folder Problem in 4.7
    I have the follow error when I create a subfolder in Media called img.
    Value cannot be null.
    Parameter name: Property contents (27) on Content Type Folder could not be retrieved for Document 1276 on Tab Page Contents. To fix this problem, delete the property and recreate it.
    And when I try to create a subfolder called documents I get the following error
    Could not find a IDataType control matching DataEditorId b6e94d0c-74ab-11df-bba6-87c4dfd72085 in the controls collection. To correct this, check the data type definition in the developer section or ensure that the package/control is installed correctly
    is there a way I can fixthis or create a document folder under my content node.
  • mph 44 posts 78 karma points
    Oct 05, 2012 @ 11:34
    mph
    Hi, I just ran into this problem today.
    Regarding the folder creation, it occurs after uninstalling the Gecko Uploadify package.
    You have to delete the data type: Gecko Uploadify
    After deleting the data type, folder can be created without errors again.
    Best regards,
    Michael
    Oct 07, 2012 @ 15:43
    Jeroen Breuer
    I've had the same problem with media an posted the solution here: http://our.umbraco.org/forum/developers/extending-umbraco/34701-Experimenting-with-base-media-types.
    Jeroen
