  • JohnC 37 posts 61 karma points
    Jun 19, 2012 @ 12:51
    JohnC
    Prefix RTE Images
    Does anyone know how i could prefix the url of all images inserted using the RTE within the umbraco backend?
    Basically, I want to presfix them something like /rte/media/123/image.jpg and then using some urlrewriting to process them using imagegen.
    Anyone done anything similar to this?
    John
    Jun 19, 2012 @ 13:48
    Tom Fulton
    Hi John,
    One solution might be to run all your RTE content through some helper function/template, that parses for images and adjusts the path as necessary.  There are a couple methods I've used to do similar functions:
    - Transforming WYSIWYG output with XSLT [blog]
    - Use the HtmlAgilityPack - example:  Wrapping Images using the Html Agility Pack, TinyMce, Umbraco [blog]
    HTH,
    Tom
    Jun 19, 2012 @ 13:53
    JohnC
    Thanks for that Tom, pretty much exactly what i should be doing, didn't even cross my mind to do that, I was expecting to edit the core and all sorts lol
  • Jan Borup Coyle 8 posts 51 karma points
    Oct 03, 2012 @ 15:02
    Jan Borup Coyle
    I have made a simpe xslt entensive to this.
    <code>
      <msxml:script language="C#" implements-prefix="myfunc">
        <![CDATA[
              public string ImagePrefix(string Value)
                  return Value.Replace("img src=\"", "img src=\"http://www.mydomain.dk/rte");
      </msxml:script>
    </code>
    Remenber to include :
      xmlns:gitsfunc="urn:myfunc"
      exclude-result-prefixes="msxml .... myfunc"
    Cheers
    Jan Borup Coyle
    Oct 03, 2012 @ 15:04
    Jan Borup Coyle
    Forgot the Body render:
              <xsl:value-of select="concat('&lt;![CDATA[ ', myfunc:ImagePrefix(./bodyText),']]&gt;')" disable-output-escaping="yes"/>
