Seems like a tiny issue that's causing me great headache, I thought I would post in the forum to help stimulate ideas to see what is possibly the culprit.
so the lightbox is not working for me when I click on the image from the gallery.
The XSLT is untouched and the files are being called in the xslt file as they should be
I checked some tools and they are showing up and I am not getting any 404 errors
I went through my templates and checked to see if I had any possible conflicts. Removed all other file calls to make sure
I moved the file calls to the templates all by themselves to see if that would help
I went and compared a fresh template with my site to see if I could spot any differences. Nothing stood out.
Have you confirmed if the JS/CSS that you are registering via XSLT are actually getting included or not?
IIRC the RegisterJavascript/Stylesheet calls require your template to have a <head runat="server"> to work properly.
If you've confirmed they're getting called, can you provide some more details on exactly what the problem is? Are you initiating thelightbox plugin somewhere?
Hey Tom thanks for the assist. Yeah I verified the files are getting included. One I use a program called HTTP watch, two I see them in the source and three I removed the css from the XSLT and checked that the css disappeared to make sure I wasn't seeing it being overwritten somewhere else and played around with stuff like that.
I verified that I do have a runat="server" in the head tag.
For the more details part. I am using the standard starterkit photogallery that umbraco offers. the only thing I did was move it to a submaster page. I was having issues in a prior post where I could not even get the images to show up which turned out I just needed to republish and they started showing up, so not sure if maybe something else odd is happening. But it does seem like a file is not getting called. I also thought maybe I have another overwriting it somewhere but I stripped out anything after it. All CSS etc.to test that theory
Lame photogallery issue
Here are the files from the XSLT
<xsl:value-of select="umbraco.library:RegisterJavaScriptFile('jQuery', 'http://ajax.aspnetcdn.com/ajax/jQuery/jquery-1.4.4.min.js')"/><xsl:value-of select="umbraco.library:RegisterJavaScriptFile('jQueryLightbox', '/scripts/jquery.lightbox-0.5.min.js')"/>
<xsl:value-of select="umbraco.library:RegisterJavaScriptFile('runwayGallery', '/scripts/runway.gallery.js')"/>
<xsl:value-of select="umbraco.library:RegisterStyleSheetFile('jQueryLightboxCss', '/css/jQueryLightbox.css')"/>
<xsl:value-of select="umbraco.library:RegisterStyleSheetFile('StarterkitGallery', '/css/StarterkitGallery.css')"/>
any thougths would be much appreciated!
Hi Mike,
-Tom
Correct source Code
<head id="ContentPlaceHolderDefault_head"><meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" /><title>
Washington 2010 - Be Still Retreat
</title><link rel="stylesheet" type="text/css" href="/css/site.css" /><link rel="stylesheet" type="text/css" href="/css/Navigation.css" />
<!--Scripts-->
<script src="http://code.jquery.com/jquery-1.7.1.min.js"></script>
<script type="text/javascript" src="/scripts/jqueryslidemenu.js"></script>
<script type="text/javascript" src="/scripts/jquery.lightbox-0.5.min.js"></script>
<script type="text/javascript" src="/scripts/musicplayer.js"></script>
<link href="/rss.aspx" rel="alternate" type="application/rss+xml" title="RSS Feed" /><link href="/commentrss.aspx" rel="alternate" type="application/rss+xml" title="Comments RSS Feed" /><link href="/photogallery/washington-2010/commentrss.aspx" rel="alternate" type="application/rss+xml" title="Comments RSS Feed for Washington 2010" /><script id="ContentPlaceHolderDefault_jQuery" type="text/javascript" src="http://ajax.aspnetcdn.com/ajax/jQuery/jquery-1.4.4.min.js"></script><script id="ContentPlaceHolderDefault_jQueryLightbox" type="text/javascript" src="/scripts/jquery.lightbox-0.5.min.js"></script><script id="ContentPlaceHolderDefault_runwayGallery" type="text/javascript" src="/scripts/runway.gallery.js"></script><link id="ContentPlaceHolderDefault_jQueryLightboxCss" rel="stylesheet" type="text/css" href="/css/jQueryLightbox.css"></link><link id="ContentPlaceHolderDefault_StarterkitGallery" rel="stylesheet" type="text/css" href="/css/StarterkitGallery.css"></link><script id="ContentPlaceHolderDefault_jquery.placeholder.js" type="text/javascript" src="/scripts/Designit_Green/jquery.placeholder.js"></script><script id="ContentPlaceHolderDefault_Designit_Green.js" type="text/javascript" src="/scripts/Designit_Green/Designit_Green.js"></script></head>
<body>
