  • Robert J. Bullock 386 posts 405 karma points
    Jul 30, 2009 @ 20:04
    Robert J. Bullock
    Can't Delete Package(s)
    Using Umbraco 4.0.2.1 and I noticed I can't delete any packages I created (ASP.NET 3.5).
    Anyone else run across this problem?
    Jul 30, 2009 @ 22:48
    Do you get any kind of errors when you are trying to delete them? If so could you please provide us with the error(s) you are getting? Otherwise I think it is hard to answer your question. I have not experienced any problems removing packages in that version.
    But please provide some more info :)
  • Richard Soeteman 4054 posts 12927 karma points MVP 3x
    Jul 31, 2009 @ 10:51
    Richard Soeteman
    Hi Robert,
    Same here  Work arround. Delete the package from the \data\packages\created\createdPackages.config file by removing the node that holds the package. I will report this on Codeplex.
    Hope it helps you for now,
    Richard
