Do you get any kind of errors when you are trying to delete them? If so could you please provide us with the error(s) you are getting? Otherwise I think it is hard to answer your question. I have not experienced any problems removing packages in that version.
Same here Work arround. Delete the package from the \data\packages\created\createdPackages.config file by removing the node that holds the package. I will report this on Codeplex.
Can't Delete Package(s)
Using Umbraco 4.0.2.1 and I noticed I can't delete any packages I created (ASP.NET 3.5).
Anyone else run across this problem?
But please provide some more info :)
Hi Robert,
Hope it helps you for now,
Richard
