  • Tom Adam 1 post 21 karma points
    Jun 24, 2012 @ 10:04
    Tom Adam
    Image Cropper Not Showing
    I have a package installed on my testing site www.propertymj.com - that allows me to use "Image Cropper", however when I try to use it on an actual site I want to develop www.hapkidocanberra.com the Image Cropper doesn't show in the Edit feature of each image.
    As this is not working, then the Razor macros are breaking, and I haven't a clue what is going wrong.
    See
    http://hapkidocanberra.com/pictures.aspx - compaired with the original
    http://propertymj.com/pictures/
    Has anyone got any ideas of where I can look first?
  • Jeroen Breuer 4908 posts 12265 karma points MVP 5x admin c-trib
    Jun 24, 2012 @ 21:58
    Jeroen Breuer
    What do you mean with "doesn't show in the Edit feature of each image"? Is the Image Cropper datatype not on the media type or aren't just the crops available? Maybe this package can help: http://our.umbraco.org/projects/backoffice-extensions/create-crops.
    Jeroen
