  • Andrew Cullen 137 posts 237 karma points
    Jun 28, 2012 @ 19:11
    Andrew Cullen
    Creating styled elements in TinyMCE
    I'm looking to allow writers to create the following snippet using TinyMCE without resorting to the HTML button:
    <div class="info">
    <h4>Info box title</h4>
    <p>Info box content</p>
    I've tried associating the TinyMCE control with a CSS sheet, and creating the appropriate ".info" style. That automatically creates a span, not a div, which I could live with by tweaking the CSS. However, the internal elements also get the class appended to them. Is there any way to use TinyMCE to provide non-technical users with structured HTML snippets without forcing those users to get more technical than they can handle?
  • Nigel Wilson 945 posts 2077 karma points
    Jun 28, 2012 @ 22:07
    Nigel Wilson
    Are you able to code the <div> into the user control / xslt / razor when outputting the data?
    That would remove the "class" assignment issue and make this possible.
    Cheers, Nigel
  • Mike Chambers 636 posts 1253 karma points c-trib
    Jun 29, 2012 @ 10:48
    Mike Chambers
    http://our.umbraco.org/wiki/how-tos/enabling-the-'template'-plugin-for-tinymce
    How's about leveraging the tinymce template plugin you could then insert your default html as above, allowing your editor to then just change the default text as they require?
  • Michael Latouche 504 posts 819 karma points MVP 4x c-trib
    Jun 29, 2012 @ 13:32
    Michael Latouche
    Hi Andre,
    You might also want to have a look at the widget dropper package: http://our.umbraco.org/projects/website-utilities/widget-dropper
    I have not used it myself, but it seems to map more or less with what you need.
    Michael.
