I have used drop down data type in my project. There are 5 text values and their relavant ids in drop down. If I am selecting value from the drop down and click on save then click on preview button on the web page it is displaying id instead of text value.
If I click on save and publish button then click on document related link on the web page it is displaying text value insted of ids.
so I want to display text value instead of ids on the web page when I click on preview button.
preview is not displaying drop down text
can any body help me?
Darpan
Hi Darpan,
That's definitely a weird one!
Can you let us know which version of Umbraco you are using and may a code snippet that you are using to output the values?
Chris
Hi Chris,
I am using umbraco v4.0.1.
thanks for the reply
