  • Jan Vermeerbergen 79 posts 112 karma points
    Jul 04, 2012 @ 11:34
    Jan Vermeerbergen
    Need some UrlRewriting assistance...
    I need a bit of help with some UrlRewriting. Basically I need to strip a directory from the URL, but I can't get it to work.
    The URL's look like this:
    http://www.websitename/realisaties/categoryname1.aspx
    http://www.websitename/realisaties/categoryname/item1.aspx
    and the resulting URL's should look like:
    http://www.websitename/categoryname1.aspx
    http://www.websitename/categoryname/item1.aspx
    You get the idea. "realisaties" needs to go.
    So far I have what is below, but it doesn't work. I get 404 errors on the pages.
    <add name="realisaties"
    virtualUrl="^~/realisaties/(.*)"
    rewriteUrlParameter="ExcludeFromClientQueryString"
    destinationUrl="~/$1"
    ignoreCase="true"
    Does anybody have any insight they would like to share with me? I'm obviously not seeing something...
    thanks,
    Jan
  • Mike Chambers 636 posts 1253 karma points c-trib
    Jul 04, 2012 @ 15:33
    Mike Chambers
    Did you touch the web.config or recycle the apppool to get your updated urlrewriting.config looked at?
    Jul 04, 2012 @ 16:32
    Jan Vermeerbergen
    Yes I did both, but no luck. I'm guessing there's a syntax error somewhere, but can't figure out what ....
    Jul 04, 2012 @ 16:35
    Mike Chambers
    do you get a page served if you navigate direct to the destination page?
    Jul 04, 2012 @ 16:40
    Jan Vermeerbergen
    That returns a 404 page
    Jul 04, 2012 @ 17:43
    Mike Chambers
    So that suggests it's not you rul rewriting that is at fault ;-), as the page you are trying to rewrite to is a 404...
    Jul 04, 2012 @ 17:46
    Jan Vermeerbergen
    Yes I believe I explained myself wrong.
    I want http://www.websitename/categoryname/item1.aspx to display www.websitename/realisaties/categoryname1.aspx but I don't want it to redirect...
    I thought of using umbracoUrlAlias but that's not really a viable option since there's over 200 pages already, and the client is adding new ones everyday. Explaining to him he needs to add the umbracoUrlAlias isn't an option...
    Jul 04, 2012 @ 17:49
    Mike Chambers
    so it's the other way round then... but you need something unique in the first url... perhaps category name?
    <add name="categoryname"
    virtualUrl="^~/(categoryname/.*)"
    destinationUrl="~/realisaties/$1"
    ignoreCase="true"
    perhaps?
