  • saif 68 posts 88 karma points
    Jul 09, 2012 @ 16:21
    saif
    bootstrap Carousel active item problem
    Hi All,
    I am using xslt to display images and wrapped with bootstrap carousel. The following code is working fine except  "active item" div. I tried to figure out but no luck. Following code  displays active image and first image from loop.
    If I comment "active item" div then on page load it displays nothing but once I click on left or right button it works perfectly.
    Please could you help me how can I display an active image on page load and images in loop.
            <div class="span6">
              <div class="hero-unit">
                <div id="myCarousel" class="carousel">
                  <div class="carousel-inner">
                   <div class="active item">
                      <img src="/Images/item1.png" />
                    <xsl:for-each select="$currentPage/* [@isDoc and string(umbracoNaviHide) != '1']">
                      <div class="item">
                      <img src="{uploadPhoto}" alt="" />
                    </xsl:for-each>
                  <a class="carousel-control left" href="#myCarousel" data-slide="prev"><img src="/Images/arrow_next_left.png" alt="" /></a>
                  <a class="carousel-control right" href="#myCarousel" data-slide="next"><img src="/Images/arrow_next_right.png"  alt="" /></a>
  • Greg McMullen 49 posts 195 karma points
    Oct 30, 2012 @ 14:27
    Greg McMullen
    From my experience with Bootstrap, you'll have to only have "active" on the first item. You might want to try and putting an if/choose statement to select the first & otherwise for each subsequent item.
    Unfortunately I have no examples. Sorry.
