  • Jay 12 posts 32 karma points
    Jul 10, 2012 @ 07:22
    Jay
    How to create tab functionality dynamically?
    i want to create (e.g: image above) tab functionality which is dynamic for every different page, is it possible to do so?
    Regards,
    Jay
  • Fuji Kusaka 2203 posts 4220 karma points
    Jul 10, 2012 @ 07:43
    Fuji Kusaka
    Hi Jay,
    Yes this is possible. You could just add some nodes under the parent nodes and have some property fields in it.
    Then you could make use of a macro file either Razor or Xslt to display those nodes as tabs from the parent page.
    Your content structure would be something like
    Content
    Default
    -- Page 1
    ---- Description
    ---- Reviews
    ---- Videos
    -- Page 2
    ---- Description 1
    ---- Reviews 2
    Displaying your tabs from Page 1 or Page 2
    <ul>
    <xsl:for-each select="$currentPage/* [@isDoc][not(umbracoNaviHide = 1)]">
      <li>
        </a>
      </li>
    </xsl:for-each>
    </ul>
    Hope this helps.
    // Fuji
