  • qeefahs 1 post 21 karma points
    Jul 11, 2012 @ 07:40
    qeefahs
    Content Without document type
    Hi all,
    Lets say i have a page with part of its content presented as bulltes consisting of text and images (e.g. Services list)? This content need to be managed by the site content editors.
    I know this could be accomplished by having a rich text editor propery or having a document type for the bullets content (which would result in a dedicated page for each item),  Is there a way to let content editors simply create new items each with image and text but they have no dedicated page?
  • Shaun 248 posts 475 karma points
    Aug 07, 2012 @ 11:56
    Shaun
    I'd use an RTE for the bullets, you can add a style to it to make em look good.
    As for the images, I'd keep them in the same doctype as the bullets, and just use a template to position/size them nicely on the frontend.
    HTH
  • Dallas 133 posts 405 karma points
    Aug 07, 2012 @ 14:24
    Dallas
    The MultiType-Datatype is another option for adding multiple items to a Document. It gives you more controls than the RTE but you don't have to have a dedicated page for each item.
    http://our.umbraco.org/projects/backoffice-extensions/multitype-datatype
    You create a new DataType using this type and select the properties the type should have. In your case you would have a text box and media picker. You can then create a Property on your DocumentType with that DataType.
    Dallas
