Add a classic ASP VBscript application within Umbraco
I have a classic ASP VBscript microsite that needs to sit within my umbraco application - either physically or as a virtual directory. It doesn't need to be managed through umbraco, and doesn't share any UI elements with the umbraco site, so it is really a seperate microsite that just needs to be under the umbraco site domain. When I try to load the directory (eg. www.domain.com/microsite/) then i get the error "No umbraco document matches the url...". I've tried setting the directory to an IIS application and also a virtual directory but no luck. I'm thinking I might be missing something really basic - does anybody know the best way to accomplish this?
Thanks.
Look in the web.cofig after umbrac reserved paths. There you can specify paths that the umbraco "engine" should exculde.
