So in the web.config of a site I'm working on, I've set umbracoUseDirectoryUrls to "true" and that used to work fine on my dev server.
Problem is: The URL's without an extension are giving me a 404 error on the production server. Is there something in IIS that I'm missing?
Looks like your server is missing the wildcard-mapping. (map everything to asp.net)
In IIS you need to do the following:
http://professionalaspnet.com/archive/2007/07/27/Configure-IIS-for-Wildcard-Extensions-in-ASP.NET.aspx
Thanks guys, that did the trick!
@Sebastiaan you forgot about the wildcard mapping :S you did that before :)
@Roel well.. it's Niel's server, not mine, he had to fix it for me ;)
Extensionless URL's give 404 error
