  • Amit Saxena 2 posts 22 karma points
    Jul 16, 2012 @ 09:09
    Amit Saxena
    Umbraco 4.7.2 and Responsive Web design
    Does Umbraco 4.7.2 supports Responsive Web design?
    Thanks for Help
    Amit
  • Stefan Kip 1614 posts 4131 karma points c-trib
    Jul 16, 2012 @ 09:19
    Stefan Kip
    Ofcourse, umbraco doesn't limit or alter the output in any way :-)
  • Simon steed 378 posts 700 karma points
    Jul 16, 2012 @ 09:40
    Simon steed
    As Kip mentioned, you have full control over the markup and any code it uses so yes Umbraco can support Responsive along with any other design methodologies you care to throw at it :-)
  • Brendan Rice 538 posts 1102 karma points
    Jul 17, 2012 @ 01:18
    Brendan Rice
    Simon and Kip are bang on, a really good starter kit you might want to look at is the Razor Estate Agensts Starter Site (http://our.umbraco.org/projects/starter-kits/razor-estate-agents-starter-site) it is reposive.
