Am having a wierd problem with my search. When i search for two words it doesn't return any results. But when i search for the first word it returns the appropriate search results.
This is my SearchResults.ascx.cs code:
using System;
using System.Linq;
using System.Web;
using System.Web.UI;
using System.Web.UI.WebControls;
using UmbracoExamine;
using Examine;
using Examine.LuceneEngine.SearchCriteria;
public partial class usercontrols_SearchResults : System.Web.UI.UserControl
Examine can't search for two words
using System;
using System.Linq;
using System.Web;
using Examine;
public string Term { get; set; }
public int Count { get; set; }
protected void Page_Load(object sender, EventArgs e)
Term = Request.QueryString["s"].ToString();
if (Term.Length > 1)
//Create search Criteria
var sc = ExamineManager.Instance.CreateSearchCriteria();
//define query
var query = sc.NodeName(Term.MultipleCharacterWildcard())
.Or()
.Field("bodyText", Term.MultipleCharacterWildcard());
// .Or()
// .Field("summary", Term.MultipleCharacterWildcard());
//or search by keyword
var results = ExamineManager.Instance.SearchProviderCollection["WebsiteSearcher"].Search(Term, true);
rp_results.DataSource = results;
Count = results.Count();
rp_results.DataBind();
//simple helper to add summary of search result
public string HighLightSummary(RepeaterItem item)
SearchResult sr = (SearchResult)item.DataItem;
if (sr.Fields.ContainsKey("bodyText"))
return umbraco.library.TruncateString(umbraco.library.StripHtml(sr.Fields["bodyText"]), 300, "...").Replace(Term, "<strong>" + Term + "</strong>");
if (sr.Fields.ContainsKey("summary"))
return umbraco.library.TruncateString(umbraco.library.StripHtml(sr.Fields["summary"]), 300, "...").Replace(Term, "<strong>" + Term + "</strong>");
return string.Empty;
public static class SearchResultExtensions
// Create a set of helper methods to make output
// cleaner.
public static string FullUrl(this SearchResult sr)
// Generate the URL for the returned node using
// the umbraco library method NiceUrl.
var urlStr = umbraco.library.NiceUrl(sr.Id);
return urlStr;
public static string GetDetails(this SearchResult sr, int length)
var contentStr = "";
var truncateStr = "...";
contentStr = sr.Fields["bodyText"];
else if (sr.Fields.ContainsKey("question"))
contentStr = sr.Fields["question"];
else if (sr.Fields.ContainsKey("answer"))
contentStr = sr.Fields["answer"];
else if (sr.Fields.ContainsKey("Name"))
contentStr = sr.Fields["name"];
// Only show the first 300 characters of the node
// contents and use that as the preview of the
// page content in the repeater.
if (contentStr.Length > length) contentStr = contentStr.Substring(0, length) + truncateStr;
return contentStr;
