  • James Crane 34 posts 80 karma points
    Aug 03, 2009 @ 17:45
    James Crane
    Creating customised datatypes
    Hi all,
    I've created a customised dropdown datatype, listing all the child nodes under a parent. This was based on the excellent article:
    http://www.nibble.be/?p=24
    One final issue I'm experiencing is how to fire the mandatory field warning. Currently the default item is 'Please select...'. I have set this to a value of -1 which didn't fire the mandatory field warning, and then tried setting it to nothing - which raised an int wrong data error.
    As always, any help is appreciated.
    JC
  • Richard Soeteman 4053 posts 12926 karma points MVP 2x
    Aug 03, 2009 @ 20:48
    Richard Soeteman
    Don't know for sure, but try to set the value to an empty string instead? It's checking for an empty field and since your value is not empty and you can't set the defaultvalue on the validator, so I think that's what you need to do, again not sure.
    Hope it helps you,
    Richard
    Aug 04, 2009 @ 09:18
    James Crane
    Hi Richard,
    Thanks for you comments, unfortunately this raises a data type exception as it's expecting an int but gets a null. I think I probably need to assess in code if the field is completed or not and then raise a failed validation event, but I'm sturggling to find out!
    JC
  • Rick Mather 42 posts 124 karma points
    Aug 04, 2009 @ 10:50
    Rick Mather
    This is only a guess really, but in normal ASP.NET you can make custom controls compatible with validators by using the 'ValidationProperty' attribute:
    http://support.microsoft.com/kb/310082
    I haven't tried this with Umbraco datatypes, and am not sure if the admin backend uses .NET validators or custom logic, but might be worth a shot.
  • Thomas Höhler 1237 posts 1709 karma points MVP
    Aug 04, 2009 @ 10:54
    Thomas Höhler
    It uses this attribute with the name of the property to validate, mostly it is "value". But I don't know how it works with the customcontrolgrapper
    Will do some tests...
    Thomas
    Aug 04, 2009 @ 18:03
    James Crane
    I've been fiddling about with Rick's suggestion but I just can't seem to get the mandatory event field to fire.
    Thomas, did you have any luck?
