  • Kenny Burns 173 posts 305 karma points
    Jul 27, 2012 @ 15:49
    Kenny Burns
    HELP!! Domain issue
    Hi Guys,
    Im not sure if this is the right place to post this but I have a major issue (v 4.7.2)
    The site was having some issues so I took it offline and was running it under another URL (domain) - all looks fine and running okay.
    Heres the funny bit - when I switch it back to the real domain name the CPU and Memory spikes like mad!! I cannot figure this out!
    I have scheduled tasks on the site - could it be a scheduled task that is still runing somewhere?!!
    Any help would be greatly appreciated on a friday afternoon!!!
    Kenny
  • Simon steed 376 posts 688 karma points
    Jul 27, 2012 @ 16:14
    Simon steed
    Obvious one, have you tried disabling the scheduled tasks to see if this is the root of the problem?
    Jul 27, 2012 @ 16:19
    Kenny Burns
    Hi Simon,
    I can't see how to do this? Should i just delete them?
    Many thanks!
    Kenny
    Jul 27, 2012 @ 16:35
    Simon steed
    IF they are running as scheduled tasks on your server, you should be able to right click and disable them from running. Where are they seutp from and what server os is it?
    Jul 27, 2012 @ 16:45
    Kenny Burns
    Ah, they are set up in Umbraco as scheduled tasks - i think i will just delete them and see if this helps.
    Kenny
    Jul 27, 2012 @ 17:57
    Kenny Burns
    Problem solved. It was nothing to do with the domain name but a legacy dll file which had a bug in it. (ImageGen but I have since upgraded and it now works great!)
    All sorted. :)
    Now for the weekend.
    Kenny
