  • Ernst Utvik 123 posts 235 karma points
    Aug 02, 2012 @ 20:41
    Ernst Utvik
    Eksponent CropUp: crops not updating on save.
    I'm using CropUp in the media section of a site Im developing on localhost on Umbraco 4.7.2. Got it kind of working but there seems to be some problems when changing the crops and saving. I basically need to recycle the app pool for the changes to show on the site. Sometimes changes to the crops doesn't show at all, even after app-pool recycle.
    Am I missing something obvious?
    Also: A forum in the project page at http://our.umbraco.org/projects/website-utilities/eksponent-cropup/ would be nice..
  • Martin Sørensen 12 posts 32 karma points
    Aug 15, 2012 @ 15:51
    Martin Sørensen
    I'm experiencing the same problem on a freshly installed Umbraco 4.8 solution. Did you ever solve the problem?
    Aug 15, 2012 @ 16:02
    Ernst Utvik
    Still no solution I'm afraid. I guess a dirty hack would be to add an event that pokes (saves) the Eksponent.CropUp.config file whenever a media item gets saved.
  • Niels Kühnel 16 posts 726 karma points
    Aug 16, 2012 @ 13:03
    Niels Kühnel
    It is/was a bug. I think I fixed it in the 1.0β4 i just uploaded at http://our.umbraco.org/projects/website-utilities/eksponent-cropup.
    The browser may also be caching images so you need to do a Ctrl+Shift+R to reload the image.
    Please let me knowif it fixed the problem. Thanks.
    Aug 16, 2012 @ 13:11
    Martin Sørensen
    Thanks for the quick reply Niels. One question; is it sufficient to replace certain dll's or do I need to uninstall and install the new version?
    Aug 16, 2012 @ 14:26
    Martin Sørensen
    Went ahead and replaced all the files - it works like a charm :-)
    Aug 16, 2012 @ 20:03
    Ernst Utvik
    Did a quick test and it worked like a charm. Thank you for the fast reply/fix!
