Execute an sql query in umbraco at time of package Installation
I have created a package in umbraco and trying to add Action
Script which will create a table in umbraco database.But When I try to
save the below action script it is giving error message:
Actions XML is malformed, either remove the text in the actions field or make sure it is correctly formed XML.
I am not able to identify what's the mistake I am doing here in below code.Please Help me out here. Thanks in advance.
Note: I am using Umbraco 4.8.0
<Action runat="install" undo="false" alias="ExecuteSql">
<![CDATA
CREATE TABLE [test_nishantBlog_Comment](
[__kp_ID] [smallint] IDENTITY(1999,1) NOT NULL,
[__fk_postID] [smallint] NOT NULL,
[Comment] [ntext] NOT NULL,
[CreationTime] [timestamp] NOT NULL,
[CommentTitle] [varchar](500) NOT NULL,
[EmailAdd] [varchar](100) NULL,
CONSTRAINT [PK_test_nishantBlog_Comment] PRIMARY KEY CLUSTERED
[__kp_ID] ASC
)WITH (PAD_INDEX = OFF, STATISTICS_NORECOMPUTE = OFF, IGNORE_DUP_KEY = OFF, ALLOW_ROW_LOCKS = ON, ALLOW_PAGE_LOCKS = ON) ON [PRIMARY]
</Action>
I have created a package in umbraco and trying to add Action Script which will create a table in umbraco database.But When I try to save the below action script it is giving error message:
Might be a shot in the wild, but shouldn't you have ]]> instead of ]> at the end of your cdata declaration?
/Dirk
And most probably also the starting <![CDATA[ (you're missing the last '[')
/Dirk
