  • Mathias Valentin 60 posts 208 karma points
    Aug 10, 2012 @ 11:23
    Mathias Valentin
    Image cropper and dpi
    I just found out that the Image cropper saves images in 96dpi, which I have come to understand is a microsoft standard.
    The problem is when I save images in Photoshop with "Save for Web and Devices", the images are saved in 72dpi (also mac standard). The cropped images will therefore be pixelated (from a designers point of view :)). I belive it's like scaling an image to 1.25 of its orginal size.
    So the question is, should I begin saving al images in 96dpi when working with Umbraco and the Image cropper or can I change the dpi setting somewhere? what do you suggest?
    A quick and dirty fix is to make the crop dimensions setting 25% greater than the desired image size in pixels, and then setting that width and height with html/css. Same method used when optimizing images for Retina displays.
    @mathiasvalentin
  • Chriztian Steinmeier 2800 posts 8791 karma points MVP 8x admin c-trib
    Aug 10, 2012 @ 12:20
    Hi Mathias,
    Do you have some tests that shows this as a problem?
    I have never seen any weirdness with this, and I don't really think it is a "real" issue, because in terms of web images, everything is always related to the amount of actual pixels in the image.
    Should be possible to do a test, something like this:
    * Create a 200px by 200px image in photoshop @ 72dpi, with some 1-pixel gridlines and some hard edges (gray squares next to white squares, etc.)
    * Save that for web
    * Upload it to Umbraco and create a couple of crops (none that would upscale the image, though)
    * Place the cropped images next to the original on the same webpage and see if there is any kind of distortion showing
    Do it all again, with a higher initial dpi setting in Photoshop ...
    /Chriztian
    Aug 10, 2012 @ 13:10
    Mathias Valentin
    Thanks for the reply Chriztian :)
    I actually don't have any public tests at this moment, but ok, you are right :) Dpi don't matter for web images, so this can't be the problem. It was a despret answer to why the cropped image, was a bit pixelated (the quality was not as good at the original image). And the only thing I could come up with was that the original image uploaded was 72dpi and the cropped image was changed to 96dpi when I downloaded it and viewed the metadata.
    The problem might be the quality setting under Image Cropper (Datatype)? I had a few problems changing the value to 100. Every time I saved the Datatype it would fall back to a setting of 90. Ended up change the pre value in the sql database under dbo.cmsDataTypePreValues. Now the value appears to be 100 but if I save the Datatype again it will fall back to 90!!
    @mathiasvalentin
    Aug 10, 2012 @ 13:15
    Ah - cool!
    Which version of Umbraco?
    Maybe check the Issue Tracker on Codeplex and see if the bug has been reported already, and if so — are there's any workarounds(?)
    /Chriztian
    Aug 10, 2012 @ 13:21
    Mathias Valentin
    version 4.7.2
    I have checked the Issue Tracker, but could't find a matching bug. :/ Found the solution/workaround with the cmsDataTypePreValues on the forum. But it seems like it's not working properly, so maybe it's time to create the issue :)
