I have created a content tree in Umbraco Content section (see picture). I have configured public access for certain member groups for all pages except the root node under Content. Root node is also login page for all pages. All pages have view access for anonymous users. I have configured several hostnames for root.
My problem is that I can't even access the root page, because I get the exception below. Umbraco somehow thinks I need to login before viewing my login page.
I get the following exception:
[HttpException (0x80004005): You must login to view this resource.]
Those red disabled symbols (not sure about the meaning) are shown for every page.
For some reason this does not happen in development environment but only in production. In development environment root node does not have red disabled symbol.
You don't want to have "public access" set on your login page, which I think is the issue here. Right click the login page and choose "Public access" and then remove it from this particular node.
Now you should be able to access the login page and enter the needed credentials.
I have not selected anything on "Member GroupsMember Groups". This is quite strange problem. Maybe it has not been saved correctly to Hive or something.
It's not where you should look either :) In the screendump you have posted all the nodes visible have the "restricted" access icon. I bet one of these nodes are supposed to act as the login page (but since the nodenames have been marked in black I can't tell) and on this particular page the should not be any restriction since people should be allowed to access this page in order to login.
Perhaps it's the root node that has the login form? Above you write that the root node does not have the restricted icon on your production environment. Try removing it by removing protection on the root node.
Hive is a concept related to Umbraco v5, which is discontinued and has nothing to do with Umbraco v4 and future versions of Umbraco.
I solved it by creating a new node (adding host names) and moving child nodes in it. Still not sure what caused it. Probably some bug in Umbraco v5 (database corruption?).
Content root not accessible
Hi Petri
Hope this helps
Hi Petri
Hope this helps.
