  • Peter Schermers 112 posts 134 karma points
    Aug 24, 2012 @ 12:54
    Peter Schermers
    Style auto applies to all text
    Whenever I make a selection of text in RTE, and choose a style to apply to the selection, all text suddenly gets selected and got this style applied to it. I just want my selection to be applied, nothing more.
    What am I doing wrong?
    PS: I have put two RTE's on the same page, could this cause a problem somehow?
    Aug 24, 2012 @ 12:55
    Peter Schermers
    *I just want my selection to have this style applied, nothing more.
    Aug 24, 2012 @ 21:52
    Hi Peter
    Could you try posting a screendump of the issue?
    Unfortunately it can sometimes be a bit of a challenge to apply custom styles to certain parts of the text in a rte field.
    How have you created the content? Is the text pasted from another website, word or something? Then you might need to correct some breaks etc. in order to have the correct paragraphs created. Once paragraphs are created correctly it should be fairly easy to apply custom defined styles. Lists however can be a challenge, as so can links.
    Aug 27, 2012 @ 14:40
    Peter Schermers
    Hi Jan,
    You were right, I had to remove the <p> tags first since the text was imported.
    Thanks!
