  • Lars Mortensen 90 posts 98 karma points
    Aug 28, 2012 @ 13:32
    Lars Mortensen
    Frontend not updateing
    I have published some changes on a umbraco site, but the changes do not take effect on the frontend.
    I have had this issue before, and I'm pretty sure the solution was to delete some temp files, I just can't find wich files it was I should delete.
    Can anyone tell me which files I should delete?
    Regards Lars Mortensen
  • Niels Lynggaard 193 posts 551 karma points
    Aug 28, 2012 @ 13:50
    Niels Lynggaard
    What version of umbraco are you running? Have you tried just touching the web.config file? Then Umbraco should rebuild its cache..
    Aug 28, 2012 @ 14:21
    Lars Mortensen
    Sorry for the lag of version number, my bad.
    The version is: 4.7.0, and the web.config trick did not work.
    Aug 28, 2012 @ 14:54
    Niels Lynggaard
    Hmmm.. Another trick in the book is to go to yoursite/umbraco/dialogs/republish.aspx?xml=true
    There you can republish all the allready published nodes.. That works sometimes for me if something isn't updated propably.
    What are the changes you made? Content, xslt, usercontrols, masterpages?
    /NileZ
    Aug 29, 2012 @ 12:48
    Lars Mortensen
    Sorry for the question, it was a user error.
    There were the frontpage and a welcome, which were alike, and the user had changed the welcome page.
    So everything works as expected.
    The welcome page is now deleted :)
