  • K.Garrein 164 posts 629 karma points
    Sep 08, 2012 @ 13:46
    K.Garrein
    Masterpage editor unusable in IE?
    I installed 4.9.0, but experience problems editing master pages in IE.
    Newlines are rendering incorrect, it is really unusable like this.
    Enter adds a row (with rownumber), but the html stays on the previous row etc.
    Any fix available for this?
  • Jeroen Breuer 4908 posts 12265 karma points MVP 5x admin c-trib
    Sep 10, 2012 @ 00:41
    Jeroen Breuer
    I assume you mean IE9? Did you use a clean install or an upgrade? If it's an upgrade it might help to clear the client dependency cache.
    Jeroen
    Sep 10, 2012 @ 08:33
    K.Garrein
    Hey.
    It was a new clean 4.9.0 install.
    The problem occurs in IE9 (also IE8 mode, probably also IE7 mode).
    In Chrome it works as it should.
    Regards.
    Kris.
