i'm using Umbraco 4.9. The tiny does not load, so i create the it.js in the umbraco_client folder and fix it. But when i move the cursor in the tiny no show the function button in menu of Umbraco.
A screenshot:
Any ideas? The javascript console don't show any error.
TinyMCE not work
Hello guys,
A screenshot:
Fabio
Clean 4.9 install and TinyMCE doens't work here either....
No solution yet...
p.s. is that a tinymce language .js...??
Solved this by making the language of the User English...not ideal for my client but bether then not having TinyMCE available...
greetings,
Chris
Hi Chris,
maybe i found the solution. You can copy and rename the en.js file for language with your country language name, for example:
italian -> it and put the new file in umbraco_client/tinymce3/langs/
Then you can change the language of user admin in italian.
It works?
Fabio
Hi Fabio,
Yours is another approach with a better result...thanks!
greetings,
Chris
