  • Steve Bridges 51 posts 72 karma points
    Sep 12, 2012 @ 07:34
    Steve Bridges
    Multinode tree picker not working?
    I am using version 4.9
    Added a datatype based on the "Multi-Node Tree Picker"
    I can see the tree on the left, but when i click on an item nothing happens.  Can't click, double click, drag or anything... simply nothing happens.
    Any thoughts on what i did wrong here?
    Sep 12, 2012 @ 07:41
    Steve Bridges
    HA!  Got it to work.  Seems to be a bug (IMHO) - but here is the issue:
    Even if xpath filter is blank - if you leave the radio button set to "Enable" - it will not "enable" ANY nodes.
    I personally think that if the filter is blank it should not filter at all - but perhaps others would disagree.
    in any case, switching the radio to disable did it.
    Sep 12, 2012 @ 09:01
    Lee Kelleher
    Hi Steve,
    I hear your frustration!  That's been a long time issue for MNTP (in uComponents, now in Umbraco default).
    Best bet is to raise a ticket on the issue tracker, that way it can be prioritised and a fix scheduled into a future release.
    http://issues.umbraco.org/issues/U4#newissue=yes
    Thanks, Lee.
