Thanks for your suggestions, but the umbracoLog-table does not say anything when I publish, should it? (I even tried publishing nodes that I know is publishable). Nothing in the eventviewer either. Now I'm manually publishing folder by folder just to try finding the troublemaker.
SELECT
TOP 1000 *FROM [umbraco_gbr].[dbo].[umbracoLog] ORDERBY id DESC
Ah, stupid of me! I had two db's open and looked in the wrong one. I do find publish information there.
I look in the logtable:
Publishing seems to be a two phase routine. First one row is logged for each page "Publish", some 2-5 rows per second. Then in the second phase notifications is sent and xml is saved. That takes 4 or more seconds per page. I guess I just have to wait patiently for up to 1 hour for the whole site to publish. A bit odd though that the dialog counter says 646 when it stops.
Frankly I do not dare to upgrade at this time. The site is to go live any day and I try not to mess things up at this time. I will upgrade a copy of the site first. Just to make sure everything goes smoothly.
Peter, I have been struggling with long publish time for a while now, and I had almost given up.
Just a minute ago I found out what the problem was all along, thanks to some log browsing (in the correct db...): the smtp settings was wrong, so the system tried to send notifications from a non existing server, hence some seconds lost on each publish.
I paused the notifications (dumped them to a folder instead) and alas - publish runs like a charm, 1/10 of a second instead of 4 seconds.
Publish (all) stops at 646 out of 658 pages ...
Hi!
When I try to publish a full site the publish dialog just won't go further than to 646 of 658 pages.
(I tried to re-publish after I changed which node should be the hostname root node.)
Can I find out the exact node publish hangs at?
TYI
Jonas Eriksson
(Umbraco 4.0.1)
You could check the umbracoLog table to see what the latest items are in there. Perhaphs that'll give you a clue.
Also, the event-viewer from windows might give a clue (if you have access to that).
HTH,
PeterD
PS: trying multiple times doesn't get it any further?
SELECT
TOP 1000 * FROM [umbraco_gbr].[dbo].[umbracoLog] ORDER BY id DESC
Hm, on my system, an entry is added once I publish a page (or republish the entire site). Do you get anything at all from the log-table?
You're running 4.0.1? You could try to update to 4.0.2.1.
Thank you for your time.
Oh, yes, it was only that - everyhing is published after 50 minutes.
Glad it's solved. What still worries me though is the amount of time it takes to publish all.....
Now publishing is fun again :-)
http://our.umbraco.org/forum/using/ui-questions/3464-Stop-all-notifications
Thanks for sharing this! I wouldn't have thought of this, but it certainly explains the long time it took for publishing.
It might help someone else in the future as well.
