  • Bjarne Fyrstenborg 1285 posts 4039 karma points MVP 8x c-trib
    Sep 21, 2012 @ 08:33
    Bjarne Fyrstenborg
    Can't empty recycle bin i 4.9.0
    Hi..
    I have upgraded Umbraco v. 4.8.0 to v.4.8.1 and then to 4.9.0 ...
    I have tested in Chrome and IE .. but when I move items to the rycle bin, I can't empty it..
    It just show the popup, but nothing happens.
    If I insted remove the files from the media items, then I am able to empty the recycle bin, with the media items..
    Anyone who knows why this happens?
    /Bjarne
    Sep 21, 2012 @ 08:56
    Bjarne Fyrstenborg
    It's probably releted to this bug here: http://issues.umbraco.org/issue/U4-764
    Sep 21, 2012 @ 09:05
    Bjarne Fyrstenborg
    But as a workaround until it's fixed I can remove the file from the media item and then delete the media item in recycle bin/empty the recycle bin as mentioned here: http://issues.umbraco.org/issue/U4-771
