  • andi 1 post 21 karma points
    Aug 13, 2009 @ 12:53
    andi
    Javascript Error using ContentPicker
    hi,
    i'm using version 4.0.2.1 and when i have a contentpicker on a site, i get an error on clicking.
    it says:
    Error: missing ( before formal parameters
    Quelldatei: http://localhost/umbraco/editContent.aspx?id=1056
    Row: 286, Col: 43
    Quelltext:
        });function ctl00_body_umbracoRedirect _chooseId() {
    anyone experiencing the same problem? (there is a space between redirect & _chosseId)
    thx a lot
    Andi
  • Tim 225 posts 690 karma points
    Aug 13, 2009 @ 13:22
    Tim
    I had a similar problem a while back which was caused by me using special characters in the alias name of my property.
    Also check that on your alias name umbracoRedirect you don't have an extra space. Umbraco does not trim alias names by default so this can cause this issue.
    T
