  • Kevin John 8 posts 28 karma points
    Oct 09, 2012 @ 16:54
    Kevin John
    Razor macro - how do I display a property alias in a list?
    Hi.  New to Umbraco, and Razor, and have read lots of docs and watched videos. I am trying to display a list of items in another page.  I am writing my first Razor scripted macro, which I want to insert in a template for the new page.
    This is what I have and this displays the name, and links to the item page.  This works OK:
    @inherits umbraco.MacroEngines.DynamicNodeContext
    @foreach (var item in Model.Children.Where("umbracoNaviHide != true").OrderBy("UpdateDate"))
        <h3>
            <a href="@item.Url">@item.Name</a>
        </h3>
    On my top level item doc. type I have a property alias called "widgetmodelDescription" - I would like to display this description under the 'item.name' above.  I have tried several things but failed.  Can anyone help?
    In addition,  under each of these top level items, I also want to show the names and descriptions of their child items, that are associated with each top level item. Example:
    Item 1 'name' + 'description'
    • Item 1 child 1 'name' + 'description'
    • Item 1 child 2 'name' + 'description'
    • Item 1 child 3 'name' + 'description'
    Item 2 'name' + 'description'
    • Item 2 child 1 'name' + 'description'
    • Item 2 child 2 'name' + 'description'
    Thanks in advance.
  • Funka! 398 posts 661 karma points
    Oct 10, 2012 @ 01:07
    Funka!
    Hi Kevin,
    To display a property value in Razor, the Model or item is a dynamic object that lets you just read it like a regular property.
    For example, you could try the following:
        <h3>
        </h3>
        <div>
            @item.widgetmodelDescription
        <ul>
            @foreach (var child in item.childWidgetDocumentTypeAlias)
                <li>@child.Name - @child.widgetmodelDescription</li>
        </ul>
    Notice that you have to fill in your own "childWidgetDocumentTypeAlias" since I don't know what that is. Also be sure to be very careful about the casing: for example, widgetmodelDescription and widgetModelDescription are NOT the same thing!
    Best of luck to you!
    Oct 12, 2012 @ 17:37
    Kevin John
    Thanks Funka. I will try that :)
