i need to translate the calendar and the returned date format of the datetimepicker in italian. I edited the file umbDateTimePicker.js.
Why doesn't Umbraco intercept the change?
the files are cached as part of the clientDependancy framework that the umbraco backend uses..
open /config/clientdependancy.config and update the version number.. then recycyle your app for good measure.
Fixed thanks
Fixed thanks
